OBD Port Location?
Old 09-25-2007, 09:34 AM
Mark G's Avatar
Default OBD Port Location?
Was not able to find the OBD Port. I read it should be down by the gas pedal. Did not see. Any suggestions? Also, can you help me with the temp sensor location? Is there more than one?
It's a 98 Discovery I.
Thank you,
Mark G
Old 09-25-2007, 10:01 AM
Default RE: OBD Port Location?
OBD2 port in under the steering column.
Old 09-25-2007, 05:14 PM
Temp sensor is located just under where your top radiator hose connects. There is the temp sending unit, and the temp switch for the AUX electric fans. You also have a temp sensor for the fuel on the driver's side of the fuel rail, and an air temp sensor on the airbox.
Old 09-25-2007, 10:38 PM
Mark G's Avatar
Thanks guys, I found it. It was really tucked up there. I cleared the temp code and checked the connections on the temp sensor. The gauge seems to be reading more normal, but I'll keep an eye on it.
Mark G
Old 09-26-2007, 06:49 PM
If you are getting hot, it is not good!!! You can drop a sleeve fast.
Make sure your coolant levels are good and if you are losing any, find out where.
jw928
12-31-2020 12:23 PM
KevinTheCook69
07-15-2012 02:19 PM
jtherien53
12-18-2008 01:22 PM
dc10freighter
06-21-2007 09:39 AM
dofbft
10-20-2006 02:09 PM
Quick Reply: OBD Port Location?
