THREE AMIGOS FIX
Old 09-24-2007, 02:59 PM
babyeater's Avatar
Default THREE AMIGOS FIX
Good day, I recently purchased a 00 Discovery II. How can I determine what exactly is causing the three amigos, and are there any scanners out there that can read or clear the fault codes? My goal is to resolve this cheap! Any direction will be much appreciated as this is my first L.R.
Old 09-24-2007, 03:32 PM
Default RE: THREE AMIGOS FIX
The codes have to be read by a shop with a Testbook capable scanner. This is what the dealer has. There are others that can do it, rovacom, autologic, but your run of the mill shop won't have it. Needs to be a rover shop. If you can't find one, call atlantic british and they will tell you where the closest autologic shop is..
Good Luck!
Old 09-25-2007, 05:36 AM
babyeater's Avatar
Thanks, is there anything I can do to prevent this from happening in the future?
Old 09-25-2007, 08:22 AM
Nope, the Bosch ABS is just very sensitive and can be tripped easily. Some Rovers are not as bad as others, brake dust and how you drive has a little to do with it.
marizcal
02-10-2020 08:34 AM
Externet
12-17-2012 04:54 AM
filmhog
07-19-2012 12:57 PM
KalahariLandyII
01-06-2009 11:44 AM
wesk
02-17-2008 10:22 PM
Quick Reply: THREE AMIGOS FIX
