Frozen navi touch-screen?
Old 04-05-2007, 07:10 PM
Max_A6's Avatar
Default Frozen navi touch-screen?
I had to pick up my LR3 from the airport garage this morning @ 35F (in VA!), and navi screen wasn't responding to any touching <insert joke here> for a while. Given we can't bypass the Acceptance screen, it would've been quite annoying if I didn't know the route. Has anybody experienced the same?
Old 04-09-2007, 02:48 PM
Jantiz's Avatar
Default RE: Frozen navi touch-screen?
No problems with mine. I do have to ask. Where you wearing gloves? The sensitivity setting on the LR3 screen does seem to be a lot lower than other Nav systems I've worked with.
Old 04-09-2007, 07:27 PM
Max_A6's Avatar
Nope, barehand.
Old 04-14-2007, 03:38 AM
wardolb's Avatar
there is an update for the nav system...but do this disconnect both negative and positive battery terminals, take a set of jumper wires and connect each end to the negative and positive cables let it sit for about 3-5 minutes its called a hard reset. that should work for a while but you need the software update
gilakinlr4
LR4
05-02-2020 07:18 PM
Zooropa
06-28-2011 07:24 PM
NEWYORKRANGE
03-26-2011 10:57 AM
ChargedRover
08-14-2009 12:27 AM
Quick Reply: Frozen navi touch-screen?
