Discovery II Electrical Library & Diagrams
and here are some more links, including the ECU manuals which are not in the RAVE. When looking at circuits, those tiny numbers are the connector numbers, switch over to electrical library and they have photos of the location and pin outs for whole connector, on Discos that have never seen daylight, much less the trail or an oil leak. You'll also want to look at the start of the manual for the color code (like K = pinK, U = blUe, etc.)
The rave and other electrical electrical diagrams I keep finding are labeled up to 2003MY. I'm working on a D2 where wires have been tampered with. The problem at the moment is that on the plug on my rear LH O2 sensor (T185) pin 4 is suppose to go to ECM plug C0635 pin number 7. Instead it's going to pin 15. I'm wondering if this is, because this diagram is 03 or that the wire was swapped. However, this particular wire does not look like it's been tampered with.
