Manual lock and key remote
Hi all, my key remote has not been working for some time now so I have been using the manual lock to lock/unlock my LR3.
Now the manual lock has stopped working, meaning the key won't lock/unlock the door. Has anyone else had to replace the lock?
Happy Holidays!
Happy Holidays!
Thanks. How hard is it to get the door panel off? I imagine that would need to be removed on the passenger side to access the green and white wire.
We also had the same issue with corroded wires that impacted the remote operation. Fixed the wires under passenger side, and then had to fix the corroded wires under driver side about a year later.
may be nothing actually needs replacement
Sometimes the locking cams, rods and levers inside the door get out of sync with each other. If the power door lock and unlock buttons on the middle dash still operate, try electrically locking and unlocking the doors a few times. Sometimes that will get the bits back in place.
If you have to tear the door card off, then try the same thing, but with your fingers. Probably nothing has broken, just bits got out of place.
I know its not the key, because I have two fobs and both stopped working at the same time. I have had issues before where the car wouldn't start unless I put it into neutral, but believe that was due to the old linkage.
Any ideas anyone?
EDIT: Will check wires today out of curiosity, but I don't think the wires are bad because the remotes work periodically. Now every time I used the manual unlock the alarm goes off but is silenced by the key being put in ignition.
bcolins
12-08-2013 09:17 PM
RROJ
10-09-2010 07:39 AM
RROJ
10-08-2010 09:56 PM
