Freelander Talk about the Land Rover Freelander within.
Diesel freelander engine not starting
Old 11-27-2006, 12:34 PM
Jubi123's Avatar
Default Diesel freelander engine not starting
Gents I have a 1998 Landrover Freelander 2.0 Diesel. I ran into problem when the drive belt broke. It got behind the timing belt cover
and caused the timing to go off resulting in valve damage.
New valves, new valves seals, new valves followers, new cylinder head gasket were installed. After this the engine was restarted and noticed that the rpm keep creeping up. The engine was switched off before severe damage takes place. The next step was that the injectors were removed for cleaning. Also the top of the injection pump was removed for inspection(bad decision). The engine never started again.
The injection pump was send to Holland for revision but I was informed that the pump was so worn out that economically it would not be worthwhile to repair. A refurbished injection pump was hereby recommended to me. refurbished pump was installed. Timing was checked(timing mark, locking flywheel) and is OK , but engine still does not want to start. It seems that the engine is not getting the gasoil.
Another test was done. A wetted cloth with gasoline was put infront of the air inlet and then tried to start the engine. The result was that the engine started and run. The engine stop when removal of the gasoline wetted cloth. But the enigine dows not want to start on diesel. What can be the problem? Need desperate help from any one that has knowledge on this subject.
Old 01-13-2007, 02:53 PM
05LandRover's Avatar
Default RE: Diesel freelander engine not starting
wow... a diesel freelander... cool!
lazerbrains
LR2
38
08-09-2023 07:54 PM
jahaddow
09-22-2021 10:23 AM
roverdisco1017
05-05-2021 09:56 AM
chelski
Freelander
05-10-2006 02:44 PM
aldenplanthire
01-22-2005 08:15 AM
Quick Reply: Diesel freelander engine not starting
