PTO good for anything?
Old 07-08-2011, 09:32 PM
UpChuck's Avatar
Default PTO good for anything?
So I was flipping though the RAVE this afternoon, and I noticed that the manual describes the Power Take-Off in our transfer case, and shows the internals existing, but that it's simply capped off at the outlet. Has anyone ever been able to successfully incorporate this into anything useful? Or is it just a vestigial reminder of what Rovers used to be built for?
Old 07-08-2011, 10:11 PM
adigerol77's Avatar
Well, it can drive a winch, street sweeper module, I'm pretty sure it could drive a Gatling gun too.
Old 07-08-2011, 10:28 PM
Chris-bob's Avatar
You have to purchase the PTO to install on the side of the t-case. Really simple to do. Bolt on a PTO and hook up a hydraulic pump and run a hyd. winch. Nothing can stop those beasties.
Old 07-08-2011, 10:33 PM
UpChuck's Avatar
I haven't been out to my truck yet to look at it, but is there even enough room to attach anything there? I'm just asking because I've never actually come across anyone talking about utilizing that. Seems like it would be a big wasted opportunity if weren't useable because a cat or something is in the way.
Old 07-08-2011, 10:36 PM
adigerol77's Avatar
Well crap, since I've got to get under mine this weekend I'm now going to take a look. Thanks for the added work
Old 07-09-2011, 11:53 AM
Got any info?
Old 07-09-2011, 12:19 PM
adigerol77's Avatar
Originally Posted by Danny Lee 97 Disco
Got any info?
Warn makes them...here's a little write up.
PTO And Driveshaft Installation
Old 07-09-2011, 06:32 PM
antichrist's Avatar
Not for Land Rovers they don't. Unless they just started.
The PTO bolts to the rear of the transfer case on Land Rovers, not the side.
Here's a thread that digresses in to a lot of info about hydraulic winches, including the PTO's to drive them.
How much winch for a Disco?
The only other thing I'm aware of for the LT230 is an overdrive, if it's still available, but won't fit the Disco without floor pan mods. It's called the Roverdrive.
http://www.roverdrives.com/
Old 07-09-2011, 06:48 PM
Roverdrive Gear Corporation - Home
But we already have overdrive, so would this essentially be adding a 5th gear to the standard autobox?
Old 07-09-2011, 09:17 PM
jafir's Avatar
Ashcroft makes an underdrive that attaches to the PTO
Ashcroft Transmissions - UNDERDRIVE
Quick Reply: PTO good for anything?
