Fuel Filter 2001 Discovery II
Old 10-26-2006, 04:41 PM
philmahr's Avatar
Default Fuel Filter 2001 Discovery II
Where is the fuel filter located on a 2001 Discovery II? I have looked behind the back right side passenger wheel and all I see is the fuel line. Am I blind? Also, do you have any tips for changing it once I find it? Thanks!
Old 10-26-2006, 06:12 PM
Default RE: Fuel Filter 2001 Discovery II
Phil,
There are no exterior fuel filters on a D2, only the sock in the tank.
Are you having a problem with your engine?
Mike
Old 11-03-2007, 05:07 PM
disco2adam's Avatar
I am having a problem with my DiscoII. It is also a 2001. The service engine soon light has been going on and off and the engine will shake or miss slightly. I changed the spark plugs and checked all the wires. I hooked up a code reader and it said the cylinder number 6 multiple missfire detected. Ive also run fuel system cleaner through the system several times. Under load the problem is more apparent and it occurs less often as rpms increase. Makes me think fuel starvation. What do you think?
Old 11-03-2007, 07:19 PM
Change the plug wires and the problem will go away.
Get a good set of wires. Everybody recommends Magnacor wires.
Old 11-03-2007, 08:47 PM
ajh's Avatar
ajh
ajh is offline
Speaking of which, where's the best place to add a filter in-line? Looking at having to run gas in Mexico and South America and having a removable filter and possibly a water separator is looking like a good idea.
Old 11-04-2007, 11:00 AM
Number 6 is a common misfire due to the position of the wire and heat failure. Buy a set of 8mm Magnacor wires, replace your old set, throw in a can of 44K to clean up all the old built up carbon and your set.
Old 10-25-2010, 04:15 PM
goutah's Avatar
Default Same issues, except code for #4 cylinder
Just joined!!!
I have been having the exact same issues as disco2adam. Except my code was for the #4 cylinder. I know you said the #6 is common, do you think that new wires would solve this one too? I just cant get past thinking its a fuel problem.
Thanks for the help.
2001 Disco 2 SE7 Stock 100k
Several problems and STILL in love...
Old 10-25-2010, 04:43 PM
Originally Posted by goutah
Just joined!!!
always start a new thread when you have a question. and yes if you don't have 8mm wires and descent plat plugs in there you can have misfires. you can also get misfires from the head gaskets failing if you have not already done them as i see you are near 100k.
bostow1
03-28-2013 11:01 AM
tim
01-21-2011 08:38 PM
tolia5
01-21-2011 12:29 PM
philmahr
10-26-2006 04:58 PM
warpig
09-24-2006 10:14 PM
Quick Reply: Fuel Filter 2001 Discovery II
