Idler pulley, replace or rebuild?
Old 01-04-2011, 08:32 AM
antichrist's Avatar
Yup, I've personally used the 6203-2RS, so I know for a fact it's correct.
In my interchange list (which I'll publish) I'm trying to indicate if it's a number from someone who has actually used it, or one they read it somewhere, i.e. second hand information, so at least a person can have a certain level of confidence in the information.
Old 10-11-2012, 08:53 AM
primussucks's Avatar
I can confirm that the 6203-2RS-12 I ordered from Amazon does NOT fit the small pulley. The inner ring is too big.
I also ordered a 6304-2RS which appears to fit the bigger pulley
Old 10-11-2012, 09:16 AM
jfall's Avatar
I tried to rebuild a D1 idler pulley.
The snap ring was simply a flat ring with pointed ends and no holes.
Could not figure out how to get that off.
Old 10-11-2012, 09:31 AM
suzukisam967m's Avatar
did my 80mm pulley last weekend. pushed the bearing out with a c clamp. napa had the 6304 on the shelf. good bearing, took 5-10 minutes to do the actual rebuild. hour total taking off the belt and reinstalling
Old 10-11-2012, 09:32 AM
car quest has the complete 70mm pulley for 20 bucks, metal and all. I wouldn't waste my time rebuilding the factory one
Old 10-11-2012, 10:59 AM
jfall's Avatar
Yeah, I ran a carquest or similar.
It is still in the Discovery I.
Probably have 40K miles on it now.
What I did not like about the carquest was:
Pulley is stamped out of steel.
Rover pulley from the factory is cast aluminum alloy.
I always go cast over stamped.
Old 10-11-2012, 11:00 AM
Rover_Hokie's Avatar
Belt Tensioner Pulley - replace the plastic pulley with a steel pulley. Gates P/N 36102.
JUKE179r (12-26-2016)
twaszak
03-29-2012 04:23 PM
ChanchoVerde
03-22-2010 10:31 AM
mamesteco
06-03-2009 06:02 PM
ChiefII
03-11-2008 10:25 PM
Quick Reply: Idler pulley, replace or rebuild?
