runaway rover
runaway rover
guy on the jeep forum was looking for a rover video
"The vehicle was on it's side, and about 20 locals were "helping" trying to flip it back on it's wheels. When they finally succeeded, you see no one set the brake and the vehicle goes rolling down the hillside and crashes like you'd see in a cartoon. "
i didn't find it but i found this..crazy
[youtube]http://www.youtube.com/watch?v=5zx3qKX_Pno[/youtube]
It doesn't have anything to do with oil cooler lines. It's more than likely from a blown turbo allowing the engine to suck crankcase oil in to the combustion chamber (could have been something else allowing lube oil in, but that's the most common scenario).
A reason to install a emergency air shut-off.
I think maybe you're thinking of this video of the runaway Land Cruiser. (I can't find the one without the half-assed commentary)
http://www.youtube.com/watch?v=nxXrAym93Wc
Once a diesel starts sucking oil in to the combustion chambers they are difficult to stop.
If it's a manual gearbox (and you can get to it through the smoke) sometimes you can get it in to gear and stall it, provided you can anchor is against something. Brakes alone wouldn't be enough.
Shutting off the air supply is the best way.
http://www.amotusa.com/Z_Dead%20Datasheets/4261.asp
