Blown Head Gasket
Old 12-10-2010, 10:11 PM
imike1007's Avatar
Default Blown Head Gasket
WHY?!?!?!?!?!?!?!?!?!?! She was doing so well.
I need to get my truck repaired. I am handy but have no time to do it myself. Does anyone know where I can get her repaired. I would love to deal with a honest mechanic that is good and affordable. How much does it cost to do this kind of repair?
I was told to replace the engine that it would be cheaper. That doesn't make sense is it true?
If you have suggestions, I am open to them. Give me a price for ideas.
Old 12-10-2010, 10:35 PM
lipadj46's Avatar
Head gasket jobs run anywhere from $1000 to $3500. If the shop you choose does not know rovers be sure to do your research and be sure they do correctly. You can DIY for $400.
Old 12-10-2010, 10:45 PM
buick215's Avatar
I am not exactly sure how much it cost to replace the head gaskets but I am sure that they cost less than replacing the engine. As for having it repaired, check with The British Rover Company. I don't know if they are honest and reasonable but they specialize in Land Rovers and are located in Broward County.
Old 12-11-2010, 12:45 AM
bosshogt's Avatar
iMike1007,
If its any consolation, I would say @ 140,000 miles on your head gaskets is a great run for an original LR part. Some poor folks bite the dust at 60k
Old 12-11-2010, 07:48 AM
Flat rate is about 11 hours labor plus parts so don't let someone charge you over $1600 plus new plug wires.
Old 12-12-2010, 10:17 AM
oysterhead's Avatar
Be sure to ask if the price includes rebuilding the heads.
Old 12-13-2010, 01:55 AM
discoboy's Avatar
A replacement or used motor is definitely not cheaper than the headgasket repair. I was just pricing out used motors on Fri, they are averaging $3000-4000.00 right now here in CA. My ticking noise is getting worse, so I am hoping for the best but may need to plan for the worse.
Old 12-13-2010, 09:45 AM
souljad9's Avatar
Originally Posted by bosshogt
iMike1007,
My head gasket started leaking at around 40k.
Old 12-14-2010, 02:14 PM
2001SE7's Avatar
Hi, isn't it a possibility the ticking is just a lifter? I need to do the top end on my Disco II because of overheating (blown head gasket) praying a sleeve hasn't dropped or cracked; I have seen some used/tested/warrantee motors on eBay "buy it now" for less than $1500.00 including shipping. Any suggestions where I should buy the gasket kit & head bolts ? Thanks.
Old 12-14-2010, 04:21 PM
2001SE7's Avatar
Mike I read the post by Chongo about why head gaskets fail. I read it thoroughly but still don't understand what will prevent the new gasket to fail for the same reason. Was the fix the adhesive on the new gaskets or his technique of the final torque of the head bolts to 68-72 ft lbs instead of the additional 90 Deg turn? I surely want to do everything I can to fix this the first time. Thanks.
Quick Reply: Blown Head Gasket
