Anti Theft Lights Keeps on Blinking
Old 07-27-2006, 11:15 AM
dikubec's Avatar
Default Anti Theft Lights Keeps on Blinking
My 97 Disco SE7 anti theft light is keep on blinking, no stereo not working and both front seats are not working also. Any ideas what's goin on? Thank you so much.
Old 07-27-2006, 03:01 PM
Default RE: Anti Theft Lights Keeps on Blinking
ORIGINAL: dikubec
What have you tested so far?? Grounds, resetting the alarm anything??
Mike
Old 07-27-2006, 03:33 PM
dikubec's Avatar
Nothing so far Mike, I have no idea what to do first. Could you layout me some steps to isolate this problem? Thank you so very much in advance.
Old 07-27-2006, 04:07 PM
Check your fuses first. How long has this been happening, what were you doing when it started?
Take your key, put it in the drivers door and slowly lock and unlock the door 3 times, if it is the alarm, it should reset it.
Mike
Old 07-27-2006, 06:33 PM
dikubec's Avatar
I will try it Mike and I will post the result later.
Thank you.
Old 07-28-2006, 05:16 PM
dikubec's Avatar
Mike, fuse is okay. Try to reset the the alarm as you said, still blinking. It's started a bout two months ago. There will be a time that the anti theft light goes off and stereo start working so does the two front seats you'll be able to adjust them. Later of the day, it will not work again. I can not think off something that started this problem. Any other idea than I can try to do more troubleshooting.
Thanks a lot Mike.
Old 07-28-2006, 05:22 PM
Brad S1's Avatar
check all your grounds!
llPANCHOll
01-03-2009 03:31 PM
AndrewPilkinton
12-05-2007 06:07 PM
Cirrus
01-21-2007 01:36 AM
golfpro
10-21-2004 01:52 AM
Quick Reply: Anti Theft Lights Keeps on Blinking
