electrically dead rover-need to get into neutral ??
http://rangerovers.net/rremedies.htm#neutral I believe you can also disconnect the selector from the transmission under the car, and then manually put it in neutral. OR you could just hook it up to some jumper cables and then put it in neutral.
Similar situation
I have a similar situation except I also have a dead battery. I do not want to jump the vehicle because that is what supposedly caused my electrical system to "short out" and now I have to replace my vehicle's computer. I need to get the car towed to be repaired and I need to know if there is a neutral/park switch on the vehicle and, if so, where is it located?
Details:
1999 DII
Replaced battery 1 month ago, but because I forgot to unhook the 6-disk cd changer and take out fuse for clock, the battery has died again
Vehicle's computer is shot - will not start anyways, even if I attempt to use jumper cables.
Any help would be greatly appreciated.
Thanks!
Details:
1999 DII
Thanks!
Mine is the same... tried to jump the battery (which is 1 year old) and nothing... Stuck in the garage in Pawleys Island... see you are in MB... any thoughts? Thanks.
