?? about resetting the alarm
I had to remove my battery in my D1 the other day to charge it and when I went to put it back in the alarm wouldn't stop going off. I tried turning the key in the lock three times but it wouldn't lock or unlock like it normally does. It felt mechanical with no electrical assistance. I tried starting the car and using the remote but couldn't. I finally locked and unlocked the rear hatch and it kicked all the actuators on so the prob was resolved but now my remote only works some of the time and it feels like one or more of the actuators are going out. Can the drivers side actuator cause this or am I missing something simple? Seems like something is about to fail but I can't figure out how to tell. What should I do the next time this happens? Thanks for the help, Jay
BTW: Everything is working ok for the moment but I am still worried. Does it matter if the hood is closed?
On a D1, you have to lock and hold it for 5 seconds with the key. You may have to repeat this. If you lock a D1 without doing this, the alarm will set. It will go off if unlocked with a key. The extra seconds keeps the alarm from setting. You can also get a new case and buttons for your alarm fob. Mine was getting really worn and I replaced it a few years ago. Works a lot better..
