DiscoMike!!! Sea Foam vs. LUCAS tune up in a bottle
Old 03-07-2008, 12:34 AM
bigugly82's Avatar
Default DiscoMike!!! Sea Foam vs. LUCAS tune up in a bottle
DiscoMike,
What is your opinion as to which is better. SeaFoam or Lucas "Tune-Up in a bottle" complete fuel treatment?
The Lucas if you can believe is around $3 per bottle where the Foam is about $5.50 per bottle. (S. Texas)
I know this my spark discussion so please try to bring fact based knowledge rather than opinions.
"Let the debate begin!"
Old 03-07-2008, 08:41 AM
Default RE: DiscoMike!!! Sea Foam vs. LUCAS tune up in a bottle
There is no debate, you are talking about doing 2 completely different procedures.
The Seafoam is to be used as an induction cleaning process, the Lucas or other gas additives are for cleaning the injectors.
Old 03-07-2008, 10:14 PM
bigugly82's Avatar
Doesn't SeaFoam in the tank do the same thing? Or am I just wasting Foam?
Old 03-08-2008, 08:12 AM
Do the same thing as what, an induction cleaning, no at all, all it does while being used in the tank is clean the injectors, when done as an induction cleaning it decarbons the valves.
Old 03-08-2008, 11:29 AM
starcraft's Avatar
I guess what we are trying to find out here is which product is better for putting into the gas tank. Yes, the seafoam is used also as an induction cleaner, but when used soleythrough thetank, is it better than the Lucas "tune-up in a bottle"? Any ideas?
As a side note on this discussion, I have heard that the fuel filter should be replaced before doing such a treatment (whether it be with lucas, seafoam, or any other product). Is this true? I'm looking to put some in my tank soon so I would like to know. Thanks alot.
Old 03-08-2008, 11:53 AM
If you are looking for an in-tank treatment, Go with B&G 44K. When you add it, try to plan on driving for a while and punching it at intervals through out. Stuff works great.
Old 03-08-2008, 12:39 PM
The fuel filter has nothing to do with how well injector cleaner works.
But yes you should change your fuel filter every 30k or so. Unless you have a DII, then you DO NOT have a fuel filter.
So, with your '03...dump it in the tank and go. I use a bottle of injector cleaner every oil change and I buy whatever is on sale. If you use good gas then it isint such a big deal. You get what you pay for, cheap gas=dirty injectors, good gas=clean injectors.
Old 03-08-2008, 01:32 PM
DITTO, B&G's 44K is by far the best, gas additive out there, some people don't like paying the $20 plu for it, but you get what you pay for. Next best id Techtron from Stand oil then Seafoam. These will clean out the system quickly. Lucas, which I really like is used onec in awhile to maintane what you have cleaned out.
Old 03-08-2008, 03:33 PM
starcraft's Avatar
Does anyone know where I can pick up some of the B&G 44K. I don't think I have seen it in my local autoparts stores but I might have missed it. Is it only online?
Old 03-08-2008, 03:44 PM
Luv2Disco's Avatar
You can get Lucas in the large bottle for about $9.99, which is good for about five tanks of gas. Notknocking the merits of other products butmytruck runsgreat using the Lucas. I'd really like to try the B&G 44K but I haven't found it in this area. I've tried NAPA, AUTO-ZONE , O'Reilly's etc. with no luck.
Quick Reply: DiscoMike!!! Sea Foam vs. LUCAS tune up in a bottle
