Engine Codes
Old 01-27-2008, 02:21 PM
ccvalentino's Avatar
Default Engine Codes
Just read my codes for my check engine light and got the following:
P0447 and P1668 Pending. P0447 refers to a Vent Control Circuit Open.
Any thoughts are greatly appreciated.
Thanks,
Chris
Old 01-27-2008, 04:21 PM
Default RE: Engine Codes
I believe your vent control is on the filler neck... Code says the circuit has an open..
check out www.iequus.com for code defs...
The other is your alarm
Old 01-27-2008, 04:25 PM
I think it pretains more to the evap system canister area more then the fuel cap, the 1668 I can't find.
Old 01-27-2008, 04:30 PM
wesk's Avatar
P1668 = Anti-Theft Alarm serial link fault Drive cycle A:Signal out of range - above maximum.
However, I have no idea what it means.
Old 01-27-2008, 04:33 PM
Thanks...Anyone have a fix for this? Does the solenoid need to be replaced?
Chris
Old 01-27-2008, 05:18 PM
On the evap system you need to talk with a mechanic for the testing procedure, scanneer may clear the 1668 with no repairs.
NWROVERS
03-10-2015 03:17 PM
csp
07-01-2013 07:33 AM
buick56
05-15-2013 06:11 PM
04SSHD
04-11-2012 06:20 PM
BajaXJ92
12-03-2009 07:43 PM
Quick Reply: Engine Codes
