Clock
Old 12-27-2007, 12:45 PM
ryant06's Avatar
Default Clock
The clock on the dash is supposed to light up right? Mine doesn't. Fuse is good, obviously. It work, just no light. Thoughts on a fix???
Trying to get my RAVE cd iso image burned onto a disk as well. No luck with that yet.
Old 12-27-2007, 12:55 PM
LRDISCO's Avatar
Default RE: Clock
I have the exact same problem.
Old 12-27-2007, 01:36 PM
zerochills's Avatar
Default RE: Clock
small light bulb behind clock, get at local auto shop or from rover connection. becareful removing clock, tabs break easily
Old 12-27-2007, 01:44 PM
ryant06's Avatar
Default RE: Clock
ORIGINAL: zerochills
thanks!
Old 12-27-2007, 01:55 PM
jmt's Avatar
jmt
jmt is offline
Default RE: Clock
I've got the same issue. If oyu get into this, please document with pictures!
Old 12-27-2007, 02:19 PM
ryant06's Avatar
Default RE: Clock
ORIGINAL: jmt
I found the light on roverconnection.com. It's $10.
Does anybody know if it comes with the instructions on installing it?
Could anybody post pictures of taking the dash apart to get to the clock?
Old 12-27-2007, 02:25 PM
zerochills's Avatar
Default RE: Clock
may want to look through recent past post, I know I saw Disco Mike had post a reply in regards to this, do not remember how in depth it got.
Old 12-27-2007, 03:06 PM
Default RE: Clock
remove the cup holder and coin/ash tray. You can pry the clock out then.
Also, get the bulb at the dealer. I paid $7 for mine. AutoZone tried to sell me the wrong wattage bulb that wouldn't even fit. Just run by the dealer.
Old 12-27-2007, 06:53 PM
jmt's Avatar
jmt
jmt is offline
Default RE: Clock
Does this apply to the 03 Dash as well? Not sure...
Old 12-27-2007, 07:41 PM
bamarover's Avatar
Default RE: Clock
i am glad i am not the only one with this problem. it annoys me at night not knowing what time it is.
Quick Reply: Clock
